biggy
Im getting what seems to be a rhythmic noise from what feels like the front end somewhere .When it first started I would notice it when travelling between 50-60 mph. Now however I have noticed that it seems to be at any speed when I am in the 2800-3000 rpm range. Above or below those rpm's and the noise is not there. You can feel it in the gas pedal and the front driver and passenger floorboards. So just to be clear this is a rhythmic noise and also a vibration.
Things I have checked
1 Rotate tires front to back. ok
2 Removed front driveshaft and drove without ds ok
3 Inspect rear ds. Appear ok
4 Checked ball joints ok
5 Torque everything I can get a wrench on for suspension and steering components ok
6 Checked diff fluid level. ok
7 Inspect front shafts ok ( upgraded to 10 factory shafts last summer )
Could this be a vibration from the motor since it only happen at certain rpm's. I'm at a loss and any input is appreciated. Thanks
