Speedy_RCW
I know, I know. Another one. I’ve read about everything out there but still can’t seem to solve my death wobble issue. It got me again today. I’ve pretty much rebuilt the entire front end. Track bar bushings replaced, drag link replaced. All control arm bushings replaced including axle side (those are a bitch). Tie rod ends replaced. Then built a new tie rod with heim joints. Unit bearings replaced. Ball joints rebuilt. Increased caster. Just installed a synergy trackbar and welded on washers to take care of wallowed holes on the trackbar frame side mount. Adjusted toe. Pretty much everything. Just soliciting ideas on what else to do. Anyone been in this position and finally found a remedy? I’m about due for tires and I know balance could possibly trigger it but it happens regardless of which tire is where. Still happens after rotation. When I look under while someone is dry steering I see no movement. When they push sideways on the jeep all I see move is tire sidewall. This thing is pissing me off. I thought I had it dicked after the new trackbar but hit my nemesis bump today and confirmed it’s not gone.
