JayKay
I just got done installing a 4' Firestik Firefly. I already had 18' coax ran and CB installed. I acquired two free antennas which both ended up being bad so I pitched them. I went without an antenna for a month (so I didn't use my CB for a month). During that month I installed an amp and a factory sub enclosure. The amp is under the passenger seat and the sub is in the factory location. Coax is ran through the passenger roll bar padding and across the top of the windshield to the CB above the rearview mirror.
After getting the antenna installed on the spare tire carrier I get radio interference in the CB. If I unhook the coax from the back of the CB, the interference goes away. The thing that has me confused is that the only place any of the new audio wiring is close to the coax is where it comes out of the tailgate and into the sub enclosure trim panel. I unhooked the subwoofer leads at the amp and the interference is still present.
The coax I have is used also. Should I get new coax with high shielding?
