aaronstephen
Does anyone have any experience with fitting an aftermarket tie rod with 15" wheels? Needing some help on figuring this one out. Thanks
Somebody correct me if I'm wrong, but I don't think that the material with which the wheels are made has any effect on whether or not a tie rod will fit. Maybe the backspacing of the wheel has something to do with it
I didn't think so. But I'm the one asking for the expertise. So I really have no idea.
The real problem lies in the size of the TRE that some aftermarket tie rods have. For instance, the Currie TRE's are massive, way beefier and stronger than a synergy or moog and you would definitely have issues with a 15" wheel whether it be steel or aluminum. You may have issues with the others as well but I can't say for sure. The type of metal used can make a difference as most aluminum wheels tend to be thicker.
I have 15" soft 8s and Synergy tie rod and it fits but there is literally no room left on either side. But it fits![]()
These are the ones I have.
http://m.discounttire.com/dtcs/find...KO&c=2&rcz=60016&pc=45682&wd=15&rw=&rc=ILCINT
Since they are the same make and backspacing you think I may be ok with fitment of the synergy tie rod?
Most likely, but it will be a tight fit.
Thanks for posting up your experience. Looks like I'll go ahead and order a Synergy Tie Rod and hope for the best.
