Rippin Lipz
I have a 2012 JKU Rubicon with an automatic transmission. Just installed a RK 3.5 lift with 38" tires. I'm currently still using 4.10 gears. I used the AEV Procal to correct the tire size. Well something just doesn't seem right. The transmission will shift all the way to fourth, then it just stays there. I have to use the tap shifter to get to fifth. I was kinda playing around with it today and I was at 4500 rpm's in fourth gear. I just held it at 4500 rpm's just to see if it would shift to fifth. Well, it never did.
So, is something wrong?
Or is it because I'm using 4.10 gears with 38" tires?
Or maybe something else?
