Foofighter3
Hi all,
I had new gears and an Aussie locker installed on my 08 2dr and when I first got it back from the shop I noticed extra jolting whenever it shifted between certain gears which turned out to be because of too much movement in the driveshaft. I took it back to the shop that did the gears, they took a look at it and found the washers that came with the locker were too thin so they put some thicker ones in there. It drives a lot better now but it still kinda jolts a little whenever I suddenly let off the gas.
Can you please check out the video and let me know if this amount of movement in the drive shaft is normal? Or is this amount of play/jolting feeling inherent to Aussie lockers and/or a higher gear ratio? Maybe I am noticing the jolt more now that I went to bigger gears? Thanks.
https://youtu.be/A96cjI1mArg
