ABS speed sensor
bharkin
I have a 10 JK. The dash lights for the ABS, traction control and BAS came on with a code for the right speed sensor fault. I replaced the sensor, however the lights have stayed on, and I am getting an occasional grab on the brakes by the computer. The code has cleared, but the lights are still on. I tried pulling the battery terminal to reset the computer, have driven over 50 miles to no avail. What am I missing?
Is your steering wheel off centered? That would cause the computer to think it has an issue and it's trying to correct itself.
Ur avatar looks really familiar! May want to chose something besides the same as the forum admin
I would say you have a bad connection at the plug or a pinched wire. Start at the plug and make sure the connection is solid, the slightest bit of play or damage can cause what you are describing. If the connection is ok you will want to check if one of the wires has been pinched or has any kind of damage.
