2017 JKUR Recon. I have the ABS and ESP lights on. Took to several places and they were unable to pull any codes. One shop used a snap on scanner and still nothing. They performed a battery test and it checked out fine. A short while later lights go out. Now several days later lights on again. Stopped at Autozone. They pulled the following codes:
C2100. Battery Voltage Low
C1027. Left rear wheel speed sensor signal erratic performance
C1020. Left rear wheel speed sensor circuit
C2102 Battery voltage low
Is this simply a left rear wheel speed sensor or do I have other issues? There is not the usual U code for the wheel speed sensor.
Thanks in advance for any advice!
