Does anyone happen to know the size of the bolts at the top of the A pillar inside the windshield ?
Mines not loose....its bloody disappeared and now squeaking like a good un !!No but, I do know they have a tendency to loosen. I've had rattles that were caused by these being loose.
pull the other one out and take it to an ACE hardware - you should be able to find a replacement
Thanks Eddie.....pulled the bolt ....trip to a hardware store now !Don't know the exact size but it is metric and requires a 13mm socket to remove. Sorry, that's about the most I can tell you without pulling the bolt.
Hi Saddle,Your bolt didn't happen to fall down behind the A pillar cover or all the way down that column behind the side dash cover did it? Just asking from experience, I have dropped a socket down that column after trying to tighten the bolts which led to a crash course in how to remove all the trim pieces, just a thought before you hit the local Dubai Home Depot,.
