Tyler2955 New member May 14, 2017 #1 My jeep starts but it won't stay running. When you turn the key, the engine comes to life but then does right away. It will continue to run if you push the gas down. Am I correct in assuming this is a problem somewhere in the fuel system?
Scrambler Member May 14, 2017 #2 Check the pressure. Only way to know for sure Sent from my iPhone using WAYALIFE mobile app
Tyler2955 New member May 14, 2017 #3 Check what, oil pressure? Sent from my SM-G930V using WAYALIFE mobile app
Tyler2955 New member May 14, 2017 #4 Scrambler said: Check the pressure. Only way to know for sure Sent from my iPhone using WAYALIFE mobile app Click to expand... Check what, oil pressure? Sent from my SM-G930V using WAYALIFE mobile app
XJADDICTION Banned May 14, 2017 #5 Fuel pressure, also could be the throttle position sensor (TPS). The TPS is easy cheap fix. Sent from my iPhone using WAYALIFE mobile app
AZ Explorer Caught the Bug May 15, 2017 #6 Every time this has happened to me, it has been a fuel filter. Cheapest, easies thing to check first.
J Justin.Tillock New member Jun 28, 2017 #8 Had a 94xj start then die. I ran a hot wire to my fuel pump to make sure it wasnt dead. Pump was good, changed cps sensor fired up n good to go. Sent from my SM-S120VL using WAYALIFE mobile app
