97 TJ wiring question
Hobolobo
Hey guys, I'm looking for the complete underside wiring for a friend's tj. He's having problems finding it, and I figured if anybody knew where to find it, it would be y'all. Or if you have the whole getup laying around, I'll take it off of your hands. Thanks.
Not sure anyone would just have this laying around. Try a junk yard
I've got a few different harnesses from Jeep part outs. What harness is he looking for? The underside isn't very specific. Also, motor/trans combo that it has will make a difference if it's the engine/trans/t-case/gas tank harness that he needs.
I know he's having issues with the fuel pump, but i he has a 4.0 w/ manual trans.
There is a short section of harness from the top of the fuel pump assembly to the frame rail. After that, it's all connected to the engine harness. Is he sure it's the wiring harness? Did you check voltage at the fuel pump plug? If you don't want to drop the tank, you can check it at the frame rail connector.
