JKPilot New member May 26, 2013 #1 So is 8000 pounds enough capacity for a JKUR under the most usual condition?
Saharaunlmtd Caught the Bug May 26, 2013 #2 U could get away with it if you use a snatch block but 9,500 to 10,000 is ideal for a JKU.
jeeeep Hooked May 26, 2013 #3 x2 on snatch block and 9500-10000, what would you consider most usual condition?
R rtguy1 New member May 26, 2013 #4 I run a 10k on my 2door in case I need to help out other rigs. There may be rigs other than jeeps out there that need a hand too
R rtguy1 New member May 27, 2013 #6 Ben-0 said: ^^thats true...what would you say for just a 2dr? Click to expand... If u only care about pulling out yourself an 8k is fine for a 2door rig
Serg5000 New member May 27, 2013 #7 I run an 8k and its never let me down. I have it mounted on my JKU. As mentioned above that when using snatch blocks it increases its capacity.
JKPilot New member May 27, 2013 #8 jeeeep said: x2 on snatch block and 9500-10000, what would you consider most usual condition? Click to expand... In my case recovery from mud most likely situation.
