Rock40
Hi, first post on this forum but not a new build. I've been documenting this over on another forum but figured there may be more interest here.
You will probably see more of the M715 than you actually WANT TO on this thread. They are fairly odd beasts that received all kinds of modifications from the military which make them quite a bit different from a civilian "J" truck. Be forewarned, I like detail, custom fabrication and extremely robust engineering.
Currently about 3.5 years into the build and I'll be slowly moving information here over time. Not my first build but it is the first Jeep build, specs below...
1968 M715 1.25 ton truck. Bone stock, 40K, spent it's entire life in interior Alaska (Fairbanks)
2001 Tilden Motorsports 8.1 liter Vortec
Ranger OD
GM SM465
Off Road Design Magnum Box
NP205
Front Axle:
GM Kingpin Dana 60, RCV 300M shafts, ARB, Reid Knuckles, 35 spine hubs, shaved housing, etc
Rear Axle:
Corporate 14 Bolt, stock shafts (until they twist and break), ARB, disc brake conversion, Artec truss
The end plan is to run a full linked and coiled suspension on 40's. Why the nickname "Smokey" you ask? Because the 8.1 liter is going to turn good rubber into white smoke. Simple, stay tuned.
Towing it back from Fairbanks...
Pics were taken close to midnight around the solstice, fantastic time of year up there
Northern Yukon traffic jam
Making friends back him with my 69' FJ40
Ranger OD
GM SM465
NP205
Front Axle:
Rear Axle:
