After seeing several discussions regarding 40" tires and running them on a factory Dana 44 axle, I thought it might be good to revive an old endurance test that Cindy and I did back in 2009. At the time, we had just trashed our factory front Dana 44 axle while running a set of 37x13.50 Toyo M/T's and decided to use the opportunity to upgrade to a Dynatrac ProRock 60. So really, what we were testing was a set of Toyo 40x15.50's on a factory rear Dana 44 axle that came out of a Jeep JK Wrangler Sahara Unlimited. Back in the day, this was all new territory and Superior had just come out with a new prototype 35 spline chromoly shaft that could be run in this axle and with an ARB. With the added strength of 35 spline shafts, we thought we might be able to just make it work but, if there was one area that we weren't too sure of, it was the ring and pinion. In order to help restore lost power, we knew we had to run a 5.38 gear but, in a Dana 44, the pinion on it is really, really small. If anything was going to break, it was going be this, but of course, we wouldn't know for sure unless we tested it out.
Soon after Moby was ready to roll, we decided to spend the summer pushing Moby as hard as we could and as long as we could. During that time, we drove to Tahoe and back twice (almost 500 miles each way and totally about 2,000) and ran a total of 9 separate trails and the following is a list of them (not including runs bombing through the desert):
1. Twin Peaks - 07/10/09
2. Hell Hole - 07/11/09
3. Slickrock - 07/15/09
4. Deer Valley (in reverse) - 07/15/09
5. Wentworth Springs/Rubicon (to the Little Sluice) - 07/18/09
6. Cleghorn - 08/02/09
7. Niagara Rim (Trail, Lions Butt & Rockpile) - 08/08/09 ~ 08/09/09
8. Rubicon (in a day) - 08/11/09
9. Dusy Ershim - 08/28/09 ~ 08/30/09
As I'm sure you can guess, our endurance test ended just 6 weeks in and on our 9th run - the Dusy Ershim. It was here that the pinion in our Dana 44 rear axle finally decided to call it quits. In the end, our initial concerns were right - No matter how much you build up your axle housing and no matter how easy you are on the skinny pedal when taking on obstacles, your weakest link will always be your internal components. Of course, this is just our experience while running 40x15.50's on a factory rear Dana 44. We were easily able to trash our factory front Dana 44 just running 37x13.50's.
