T TJ KID New member Aug 24, 2015 #1 Installed a body lift and will shift 2h and 4h but not 4l. Should there be a bracket or something for the linkage
jeff_in_rc New member Aug 24, 2015 #2 You may have to re-adjust the shift linkage for the t-case due to the lift as it might be binding up on you. Or you could go one step better and replace the linkage with the Novak shifter cable and it won't bind up on you again.
Moabbnd New member Aug 25, 2015 #4 Yep, just a simple adjustment. Novak, or the improved Savvy cable shifter both work perfectly
