4 banger won't start
Sugarbear
I have a friend with a YJ 4 banger she started it yesterday pushed the clutch in stuck it in reverse and it shut off and now won't restart any idea what this could be ??
Boy, you're gonna get a ton on this one. It's a total failure so it's most likely fuel or ignition. Check for fuel at the carb and then spark. Four poppers are fairly simple to diagnose. Lots of folks are gonna answer your 911. Good luck! :yup:
Does that puppy have a neutral safety switch? Could be a problem
Sent from my XT907 using WAYALIFE mobile app
It starts but shuts off right away I haven't personally looked at it yet but I don't know exactly where to start
If it starts then dies suddenly I'd check the fuel filter and if its clean check the fuel pump.
Sent from my Z796C using WAYALIFE mobile app
If it starts then shuts right off my money is on the mass air sensor. I think its called a MAP sensor
Cant see where you are located, but if its real cold that could be part of it. A truck I used to have was carburated and when it was cold it would stall if I didnt let it fully warm up at idle (exhaust had to stop looking white) and wouldnt restart if it stalled. When stalled I had to let it sit for an hour or 2 before it would restart and it would rough idle and run like shit till warm.
Maybe low compression?
This is also a long shot since I don't know how early they started programing keys. But if it needs to have a transponder key. And they had a new key cut. It would act like this
