I am having to replace my fuel pump in a 2000 Tj and wondering if anyone else has done this? Curious about just cutting a hole in the back to get to pump without dropping tank since it's becoming a toy more than DD.
It isn't really that hard to drop the fuel tank on those. I just put a jack under my tank and lower it enough to take all the fuel lines off. The hardest part for me was taking off the wire connector. If it was me I would not want to cut a hole in the back just to replace the fuel pump.
It's not a hard task to do especially if you have a buddy to help. I just did mine last month, took maybe 45 min. There are 4-5 nuts that need to be removed on the rear of the tank and another 3 on the front( 1 on the passenger side, 2 on the driver side) and the whole tank and skid drops down. Pull the pump out and replace. I'd recommend cleaning the tank out to. I should have but was restricted on time.
