You are more likely to break an axle shaft any day of the week than you are to break an axle housing. Assuming you have a Rubicon, chromoly shafts with full circle clips is what I would gotten over sleeves. If you have a 2-door, you will want to get a new rear 1350 shaft sooner than later as the amount of lift needed to clear your 37's will be significant enough that your factory shaft will fail sooner than later. If you have automatic or a 2012-up, you will want to get a front shaft too. While 5.38's will give you a nice ratio for 37's, the pinion on a Dana 44 will be really really small and will be a weak point. I would not recommend anything bigger than a 5.13 here.
