Gears in a new jeep. How much difference does it make say when towing or if you are running 315 70s and towing And on anew jeep what size lift is the minimum to run 315 70
Every bit of gearing helps when you're towing a brick with a brick. For short periods of towing, 373s will be ok but if you plan on towing to capacity long distances there is no reason not to go 4.10 unless you have regearing in your future.
Leveling kit and chopped flares will be the minimum for those tires.
Always mean to ask you but forget - whats the weight of your trailer?
