Jkmaxxx2011
Typical jeep driver always wanting bigger tires! I have a 2011 unlimited rubi with 4.11s how are 35s going to handle with them or should I just wait to buy 4.88s
Well, first off, you have 4.10's not 11's :crazyeyes: But, to answer your question, it won't be so bad so long as you make sure to recalibrate your speedometer. Your speedo controls your shift points and if it's off, it'll make your Jeep feel worse that it is. If you can afford to regear, 4.88's will bring you back up to about stock performance and 5.13's will give you a bit more pep.
Ahhhh okay. Keep seeing people running them but I felt like it'd be pushing it
Eddy I have a question for you. I live in fresno ca very close to the dusy trail. Do you plan on doing it again?? Did you enjoy it??
Like I said, so long as you make sure to recalibrate your speedo, it isn't too bad. It'd be better to regear for sure but, 4.10's and 35's can be tollerable.
I drive a really wide JK, 88" wide and running the Dusy in it is a pain. The trail is really really long, dusty, super narrow and exhausting more than it is difficult. I really like the first 10 miles and the last 10 miles of it but, the middle 10 just sucks the life out of you. Will I do it again, sure, but it won't be anytime soon. Maybe August at the soonest.
That's what I've heard it that it's "too long". While you were hear did you do any of the "bald mountain trail"
We haven't done Bald yet but, we've done Red, Coyote and Swamp as well as a few of the easier off shoots in the area. Fun stuff, we love it up there :yup:
How does one recalibrate our speedos????
The cheapest way is to buy an AEV ProCal. It'll allow you to do this. A lot of programmers like a Hypertec or Superchips will allow you to do this as well but, they are more expensive.
Eddy, I have a 2011 Unlimited Rubicon with the stock 4.1 ratios and I am running 32.5" Maxxis Bighorns. Power on the open road is ok if I have the overdrive switched off, but with the overdrive on there is just no power. Remember we are running 120km/h on our roads, and with the overdrive on this means about 2000rpm's, meaning no power to push this brick shape through the wind at 120. So I bought 5.38 ratios, planning to fit 35" wheels and to gain some power as well 'cause sometimes I tow my offroad trailer which is about 1.3 tons fully loaded. Fitting the 5.38 ratios would mean that I can use the overdrive as well when towing, 'cause I will be running close to 2600 rpm at 120 with 35's. That should give me enough power to tow and bring the gear ratios closer for 1, 2 and 3. But somewhere I read that you had issues with your 5.38 ratios because the pinion is too thin. This is a concern and I have decided now not to fit the 5.38 ratios, but to swap them for 5.13 maybe. Do you think this will be a good option (5.13 ratios) for towing at 120 on 35's?
The 32.5" is the actual tyre size, it is a rough measurement. They say it is 33", but not really. I used the AEV Procall Module to recalibrate the speedo and shifting points, was a bit better, but still not good enough for towing.
Will you recommend the 5.13 ratios with 35's? Is it ok to tow 1.3 ton with the overdrive switched on?
