Hahahhahaha. I have the rim, and really
How can I make it fit? Lol
I'm in the proses on mounting the rim on .
well you are incredibly vague on the problem.... Mine fits.... so im a lil confused
Unbolt 3 lug nuts from factory spare
Drop factory spare from tire carrier
Lift new spare tire off the ground
Struggle getting it to line up with the holes while sweating in the 100 degree heat
Stick the lugs in the holes
Replace factory lug nuts
Make sense?
Dont you need a spacer with a 12.5" wide tire? Or is that only if you have a 35 or bigger?
u need spacer. I have 1.75 of spacers in the 4 tires.
You need it for the spare unless you take one off your other tires and don't drive the jeep.
Make sense?
Oh you have that other jk rim. Idk what it came on and I only see it every now and then. Kinda cool because its different
