Pretty Fly
Im wanting to piece together my own lift on a 2014 Rubicon X (unlimited). I will be running 305/70/17 on a rim with 4.75 Backspacing. I have run these tires with no bump spacers and had minor rubbing front and rear at full flex. Im thinking:
EVO 3" plushride springs
EVO spec King 2.0 shocks
Currie front lower control arms
Currie Rear upper control arms
Currie front rack bar
Rear track bar bracket, not sure which one yet but I dont want to cut or weld unless I have too. Maybe Metal Cloak?
Crown extended brake lines
Move rear sway bar links to the front, extended links for the rear
JKS front bump stops (adjustable but I want to set to 2")
Rock Krawler 2" rear bumpstops
Front drive shaft. Probably go with Adams, I hope to not use exhaust spacers with the smaller diameter drive shaft??
Am I missing anything or setting myself up for trouble? I will probably add drag link flip kit in the future if it can wait. I would like to see how it is without and how much lift I acually get. I know I would have to run 3" bump spacing with a flip kit. Thanks guys, I have come up with this list mostly from searching posts here.
