AJK
Just got my Jeep back from the shop from having the head replaced. 49k miles and the infamous 3.6L cracked head problem got me. Came back from vacation started up the Jeep and it started idling rough and the check engine light came on. Then it smoothed out. Ran to the store at idle it had a little hesitation but seemed to run fine once above idle. I got back home hooked my scanner up and a P0306 code (#6 misfire code). Did some inter web searching to find that any misfire code on a left side cylinder could be evidence of the 3.6L cracked head problem. Took it down to my local dealership told them what I had come up with they did a leak down check and sure enough #6 cylinder wouldn't hold compression. Seems this may be more of a problem then Chrysler is letting on. My local dealer took real good care of me taking it right in and fixing it in three days. Just giving you guys a heads up if you have a 2012-2013 and the left side of the motor ticks a little louder then normal or you start getting misfire codes you better get it checked out.
