rob_bunch
I have a question regarding aftermarket lockers for an 2018 JLU Rubi..
At 75k I had the first rear locker changed under warranty because the locker lights and trac light started flashing,,, well it happened again at 115k and so I bought the tazer bypass pigtail & problem was solved. A few weeks back, a noise started coming from the back and I tracked it to the hub bearings (so I thought),,, we got into it yesterday and bearings were worn but not destroyed. Put it all back together test drove and still had noise in the pumpkin. Cracked the rear case open to find the oem locker was toast and the wire was shredded.
My gears have some knifing so ill have to change them too. My question is who makes a good mechanical locker for the JL. I don’t want air and honestly if I can eliminate the electric locker type I would. This is my daily diver and need practical suggestions,, thanks in advance.
