Hi
Bought my Jeep at the beginning of the summer at a used car dealer. He gave us two keys, the master one and a service one that was replaced since the original service (2nd) key was lost.
Tried to turn on the engine with the 2nd key and the engine turns on for a few seconds then stops.
I understand that the 2nd key might have not been programmed with the Jeep computer.
How do I do that myself ? Is it possible ?
here you go straight from the owners manual:
Programming Additional Transmitters
Vehicles will be shipped from the assembly plants with
two key fob transmitters programmed only for that
vehicle. A total of eight key fobs can be programmed for
your vehicle. Additional key fobs can be programmed to
your vehicle through the use of a currently programmed
fob.
NOTE: When entering the program mode using that
key fob, all other programmed key fobs will be erased
and you will have to reprogram them for your vehicle.
Use the following procedure to program additional key
fobs if the vehicle is not equipped with a Sentry Key:
1. Enter the vehicle and close all of the doors.
2. Fasten your seat belt (Fastening the seat belt will
cancel any chiming that may confuse you during this
programming procedure).
3. Place the ignition key into the ignition.
4. Turn the ignition to the ON position. Do not start the
engine.
5. Press and hold the UNLOCK button.
6. After holding the UNLOCK button for four seconds,
also press the PANIC button within six seconds.
7. When a single chime is heard, release both buttons.
The chime is an indication that you have successfully
entered program mode. All key fobs that are to be
programmed must be done so within 60 seconds of when
the chime was heard.
8. Using the key fob to be programmed, press and
release both the LOCK and UNLOCK buttons, simultaneously.
9. A single chime will be heard.
10. Within four seconds of hearing the chime, press and
release the UNLOCK button.
11. A single chime will be heard.
12. Repeat steps 8 through 10 to program up to six
additional key fobs.
13. Turn the ignition to the OFF position.
14. Your vehicle will remain in program mode up to 60
seconds from when the original chime was heard. After
60 seconds, all programmed key fobs function normally.
NOTE: If you do not have a programmed RKE key fob,
contact your authorized dealer for details.
