2" coil spacers on '01 TJ SE
JayKay
Got a 2" spacer lift for my father-in-law's 2001 TJ SE. Do I need to worry about the driveshafts with a 2" lift? I've never lifted a TJ before. I'm more familiar with JKs. Any input would be appreciated.
Not for only 2" of lift you won't have to worry about driveshafts.
You won't really need to worry about a driveshaft. You may want to consider a SYE though but even that's not necessary.
As Jiffy said, not needed but a nice thing to have. I'm running 4'' of lift and I have a SYE and shaft sitting here waiting to go in this weekend. The Vibes are liveable, but annoying. 2'' of lift, you'll be fine.
thinking of going 3.5 lift, will i need to worry about driveshaft?
I have about 3.75 of a lift and have minor vibes. I plan on installing an sye/cv kit this summer. You could always look into a TC drop if you get bad vibes. It would hold you over until you can install a sye and cv drive shaft. But if you do a TC drop, i'd try to get it off as soon as you could.
You will also need rear upper adjustable control arms to do a sye/cv kit...
also you may need rear shock relocation brackets as well as either an adjustable rear track bar with a heim or johnny joint at one or both ends of it, OR a cv style track bar relocation bracket
