gtony12
2.5" BB spacer lift sway bar links HELP?
Is there any reason why when installing the sway bar links the jeep has to be on the ground? I installed the lift and sway bar links but didn't see the note to only install links while the tires where on ground. Any input? Should remove and re-install? Thank you for the help!
