Parker "P.T." JK
I'm going to drop a 180 degree thermostat in the Jeep since it likes to run hot. Pro's and Con's?
What do u mean by "running hot" because when I got my first jk I thought it was Runnin hot too till I found out most all Jk's run with the needle in the middle of the temp gauge.... So I'm curious of this too about the 180 the stat.... I have a jet chip that states I NEED a 180° T-stat
you must be running the stageII module? I had this on my 2005 GC Hemi and it did make it run hotter without the 180° thermostat, also made it run kind of crappy without changing the thermostat, once I changed out the thermostat it ran at normal operating temp, guess advancing the timing and fuel ratios really did change... I miss that Hemi
To the original OP, how often do you do a complete coolant change? if it's been a while, I'd recommend having the radiator professionally flushed before changing the thermostat.
