desertrunner
So i just installed a set of 4 dr springs on my 2 dr. I got a few questions about how much lift I actually got out of it. Unfortunately i forgot to measure the fender height before i put the springs in BUT i just came across this picture.... and took some measurements.
on the spring perch measurement i got a hair over 11 3/4" and on the shock measurement i got 20 3/4" so IF i took those measurements right AND IF that picture is still good for a stock 12' sport it looks like i in fact got about 2 1/4" of lift out of the 4dr springs. Now i have read about there being 2 different sets of 4 dr springs 18/59 and 19/60s ???? (i could be wrong) but the sticker tags on the springs that i have in stalled on the Rear say 4460AA and the Front says 6318AC so does that mean i have a 18/60 combo??? or am i reading the Tag wrong for what people are referencing as 18/59?
Next question is about adding longer shocks to replace the stock rubi ones i put in there. if i got 2 1/4" of lift out of those springs i should be good to add some shocks for a 0-2" lift right? My only concern is needing new break lines to get the full amount of droop out of the longer shocks. Pulling the old springs and shocks out it didnt look like they had much extra length in fact we had to un bolt the hard line from the frame to get enough droop on the axle to get the new springs in easy. Has anyone had to get longer break lines for adding 2" of lift? True test would be to go cycle the suspension but i want to know what to expect before i buy some new shocks.
