Five-N9ne
My Niner decided the unibody didn’t want to unibody anymore… so I bought my buddy Will’s old XJ that I’d helped him build 13 years ago. Moved the 5.9 seats in including the split bench, made the ZJ seat controls power the XJ rails (this is the first XJ I’ve ever seen in person with a power passenger rail and factory heated seat switches), redid the carpet and headliner, and fixed a bunch of wiring with a Painless harness for all accessory wiring. It got totaled less than a week after I finished doing everything… texter wasn’t paying attention and smacked the front quarter from behind while I was pulled over helping a guy that ran out of gas.
Because its over 20 years old I don’t need the title to register it in CT, and the insurance company can’t force me to produce a title… so through a miracle of a loophole she’s still on the road. Re-resurrected her with parts from a donor XJ and some quality time with a frame straightener. Pics are from when I got it, the first resurrection, the accident damage, and the current state.
Quick load out:
3” BDS springs
Fox 2.0 reservoirs with valving modification, Fox stabilizer
Clayton short control arms with Giiro joints
Clayton HD track bar and bracket with Giiro joint on the frame side
OEM Liberty disc swap on the rear
29sp ChryCo axle with Aussie
HP30 swap with tube sleeves
Solid diff covers
SYE
Azzy’s t case heim linkage
Currie steering
Older Warn winch rotated 90 degrees back to tuck behind the bumper instead of blocking the radiator, Factor55 Ultrahook
JK takeoffs with OEM Rubicon sized Trail Grapplers
Overland WJ steering wheel
Fabricated MDF sub box that fits inside the spare tire
5.9 Limited ZJ front and rear seats with full power and heat, 5.9 console lid, 5.9 shifter knob
OEM door tweeters
Painless Trail Rocker for lights/compressor/efan/inverter
Viper coil with Accel DIY plug wires
There’s a bunch of other random goodies here and there. The drivetrain minus the ignition coil, SYE and a near stock sound exhaust is otherwise stock and will stay that way.
I’ll load more pics when I find them on my old phone.
Quick load out:
3” BDS springs
Solid diff covers
SYE
Currie steering
OEM door tweeters
