I mentioned in another post one of the coil connector lock tabs was missing, allowing the connector to work loose.
Found the connector but holy shit, price for one connector ranged from $128 - $267 🤯
The only piece I need is the locking tab, I used a low profile zip tie (outlined in white) to insert into the connector and hold the portion of the lock clip firm on the coil. I used a 2nd zip tie (not shown) to help keep the zip tie from working loose.
Locked in place:
Updating this post, I was pretty pissed at the price Jeep was charging for this connector do I went on a cross-vehicle connector search mission and jackpot, this exact connector (all number stamps identical) is used by Tesla and Ram, the cost for the Tesla connector on e-bay $7.00!
Ordered and will be waiting after the NYKOR ... fucking Stellantis
Is that a Delphi connector? I may be able to get it at work lol
When you buy a $250 Chineseum bumper off Amazon
Helped a friend install a winch bumper and winch on his Wrangler last night. As I tighten the first two nuts, one stud stripped and the other snapped off. There’s no way this bumper is strong enough to winch with. I had to grind the nut to remove the bumper. The holes on the frame horns needed to be slotted because the bolt pattern of the bumper was off by a half of a hole.
Learning has occurred.
it’s the auxbeam switch panel so it has the solid state relays and all I have to connect to it is the power and ground on it so if I’m looking at it right since it would run off the same power wire it would turn on the camera or reverse light when the switch panel powers the lights on so running that diode would keep em separate right?
I just have mine wired to the back up light circuit, after 5 years of use and wheeling I have never come across a situation where a switched circuit to turn them on was “needed” or even considered.
Having bright back up lights however, I use almost daily
once a week
iu
The lights are 6 mode so it has amber functions I use as dust lights
it's an Amazon china knock-off, paint begin to peel and rust after the 1st wash lol.
I'm seeing more take-offs for sale at a much better price then previous, might remove it and replace it with OEM over the summer.
Ooooh, ok. Thought it was the OEM steel. Makes sense now, still looks good though.
**Update**
Turned out to be a leaking hose. Small clamp fixed the issue so I took the radiator back for a refund.
I changed to oil this morning. Then the Jeep found out I had a little money in my account and decided to dump her original radiator at 157,779 miles.
