ACM 2.0 - ARB Under Hood Single Air Compressor Mount
NOW AVAILABLE for use with the all NEW CKBLA12 Brushless ARB
Installs on 3.6L and 2.0L Turbo engines only. Will NOT work on a 3.0L diesel, 4Xe or 392
Hey everyone, I'm happy to announce that the WAYALIFE ACM, under the hood air compressor mount for Jeep JL Wrangler and JT Gladiator, has been redesigned and will now work with both the original ARB CKMA12 (still great and affordable) and the all NEW CKBLA12 Brushless Single Air Compressor (compact but will put out about as much air as the original twin)! As before, the ACM 2.0 is still designed to be installed under the hood and up against the firewall to help keep it from taking up valuable space inside your Jeep and maybe more importantly, to help keep the loud sound it makes when running, out of it as well. Of course, if you're wanting to run ARB air lockers on your axles, the ACM will make plumbing air lines to the compressor super easy. Unlike before, the ACM is now made out of laser cut and bent stainless steel, comes with an aluminum heat shield and includes all the hardware necessary for installation. As always, absolutely no drilling or cutting is required.
• Works with original ARB or NEW Brushless Single Compressor
• Laser cut and bent stainless steel mount
• Comes with aluminum heat shield
• Metric hardware included
• NO drilling or cutting required
• Installs using basic tools
• Made in the USA
CLICK ON THE LINK BELOW TO BUY YOURS TODAY
(y)
Does this also work with the 2.0L Turbo with the E-Torque battery system? Asking because it seems that battery coolant lines run close to this area.
making me rethink my whole ARB install 🤬 (y) 🤔🤪
LOL - just empty every pocket 😁
Still have the original ACM on Lisa's jeep. Best way to mount it and I'm sure this is even better.
Awesome that you're still happy with yours :)
What I can tell you is that a lot of people with a 2.0L run this mount.
