Motive Products Power Bleeder
For those of you who don't know, Cindy and I started to have issues with our brakes not working while we were on the Top of the World trail in Moab. This is the same problem we had back during the New Year Kick Off Run and let me tell you, it's no bueno. Anyway, finally got a chance to wash and work our our Gladiator.
After talking to jeeeep who apparently had a similar problem in the past, I decide to give this Power Bleeder made by Motive Products a try.
Fortunately, it's super easy to use and it makes bleeding brakes super easy and without needing the help of someone pushing on the brake pedal for you.
After you hook it up to your master cylinder and pump it up to 15 psi, all you need to do is open up the valves on your brakes and let it bleed out.
I should note that unlike when someone presses on the brake pedal, the flow coming out of the bleeder valve is low but it's still enough to see bubbles and or crud coming out.
Overall, the process is super easy to do and definitely something I'd recommend if you're in need of bleeding your brakes by yourself.
Here's a link to what I bought:
But, I should note that you will need to buy this adapter as well to make it work on a Jeep master cylinder but it still comes out to being cheaper than buying the kit with additional caps:
I should note that we had bled our brakes the best we could before heading for home and that helped but not as much as we would have preferred. That is the reason why I decided to do it again and with this. And, when I did it, there weren't any more bubbles but I did see gunk come out and so I kept doing it until the fluid ran clean. And, so far, things feel a LOT better or at least, for now anyway. If this doesn't work, I'll be replacing the master cylinder next.
Glad you were able to get your brakes improved. Hopefully this bleed will be the fix and something you won’t have to worry about anymore. The kit looks nice, not a bad price either.
I just bought a Motive about 6 months ago and wish I had done it sooner in life. I also bought one of these brake pedal holders so I can use my JScan to do the ABS bleed procedure on my own. I highly recommend doing the ABS bleed. It is the only thing that got rid of the double-pump I have had to do since early on in the jeep's lifespan.
Glad to hear it's improved! That's a huge bummer you've been dealing with this the last couple of runs but hopefully it's all good now.
Here's to hoping. Seemed like we got it fixed after the NYKOR but it showed up again in Moab so we'll see.
I like that a lot more than bleeding at the caliper. Have you tried bleeding the ABS pump? I didn't even know that was a thing until recently.
Yeah, did that out in Moab. Fortunately, Mel had a scan tool to do it but unfortunately, it didn't help. Either the fluid was bad or there's something off with the master cylinder. That's the only thing left to check.
Hey, that's a nifty tool!
Hope it stays good after you got the gunk out, that's what I also experienced and weird that it happened like it did.
My 1st thought was corroded O-ring, but no leaks and haven't had an issue since.
