Dubaibentzen
Just stumbled upon this build. Looks great! Does the CC tire carrier just bolt up to the stock hinges for the tailgate, or did you have to drill holes?
Thanks.
Its a very easy install. No drilling in the car and bolt on everything using existing holes. Only thing you have to cut or grind is two original bolts and swap them with the two bigger bolts supplied for the bigger brackets.
