Seriously I am pumped for this trip! Can't come soon enough!
50 QT ARB Fridge/Freezer
I LOVE mine!!!!
Yea I'm pretty pumped to get it.
I am having a little issue with the rear plug in my jeep though... the ARB seems to think that my battery power is dropping or something... it tends to go into "reserve" mode or whatever you call it.
You need to run a direct line from your battery with a heavy gauge wire to wherever you want to plug your fridge. The factory wire is too small of a wire and it won't work well. ARB sells a kit to do this but, you can go to any autoparts store and make your own setup.
Thanks for the heads up on this. I only have the one plug in the dash so I'll probably look to add on in the back for the fridge.
What gauge wire do you recommend for a DIY kit?
Mine wouldn't work on the rear plug. But it will work on the center console one.
How long is the supplied power cord? I don't have a rear plug so I'll have to add one in the back or run it to the dash from the back seat.
If I recall, I used 10 gauge wires. You will also want to have an inline fuse on the power lead.
I have a whole roll of 8 gauge in the garage and I think a 50 amp inline fuse you can have. Would that be enough amps?
50amp. Lol
20 should work fine
Does a 15 amp fuse sound about right for this?
Hm... Disclaimer: I know jack sh!t about electrical.
So you're saying my 50 amp fuse for my 3 55w driving lights is maybe overkill???
