joelbarras20
It seems like on my last trip I ripped off my rear drive shaft boot, I fixing to upgrade axles and drive shafts in march. Was wondering how worried I need to be about this?
Sorry to revive an old thread. Was doing a little carnage inspection after this weekends fun. Found my rear drive shaft boot is goners. How long can I get away with this?? I need to re-gear, add rear air bumps and up the rear spring rates...so I am hoping the drive shaft is going to last me a while.
I noticed too that the shaft seems to rub the tank skid plate some too. Must be all the flex you get from the coil overs (I'm running the ORE bolt-ons LCG setup).
Yep, mine rubbed the gas tank skid when I installed my bolt on's a couple years ago. Took care of it with a Double D long arm which stopped the severe axle swipe when flexing.
Are we talking about the end joints or the spline boot in the middle of the shaft?
What about simply replacing the boot?
Good luck finding a replacement. You won't find one at the dealership anyway.
I've seen people buy the rebuild kits for the stock shafts that are like $150 but in my opinion that's stupid because you can get a new 1310 shaft for about $300 more.
I didn't realize that the rebuild kit came with a new slip shaft boot, just the components needed for the CV joint. That's good to know but, I agree - for $150, I would just forward that toward a new shaft.
You are correct they do not come with the boot. I just looked and the boot is like $30 and the rebuild kit is $110. So $150 total but they are separate, my mistake. Either way, waste of money.
