JK's JK
Banned
I don't usually have a problem with material since I inventory my parts BEFORE I start an install.
I guess a check off list would be recommended
It's funny the first couple hundred kits went on just fine. It's your lack of experience not the part.
Well, before jumping to conclusions here (I was thinking out loud), I was talking about the top of the shock. The bolt that's provided by King and the black allen head bolt to support the shock on the tower. I noticed when I torqued the bolt on the shock and went to place the black bolt through, it would not fit due to the threads going through the nut. When I loosened everthing up and re-torqued the nut/ bolt, I could not get my allen head onto that black bolt at all. So what I had to do was loosen that bolt that supports the sock and get the black allen head bolt all the way in, torque those down before I could tighten the bolt supporting the shock down. I talked with EVO MFG about and he said those new bolts should have gone way from that......
And yes I do have a lack of experience, a lack of experience with installing these CO's. You worked for EVO at one point so you personally know exactly what needs modifying and the next step in installing the set up. Look at it at my point of view. I have no working knowledge of the setup at all and when your given material, instructions and your rig to install this stuff and then run into problems. It's just frustrating for a person.
Buy I can guarantee you that I wont run into the same problems the second time installing the rear CO's on Lee's rig or Brandons.
^^This^^ Plus you're just a little too quick to point the hate finger and smear the reputation of a company that you yourself swear by.
No hate finger. When talking with EVO MFG this morning, a seperate company packages there material for them. So it was that companies quality control that I have a issue with. I have not said anything about smearing anyone's rep here. I've complained about instructions and missing material. I have not said anything about performance, quality or workman ship.
Just on a side note since everyone is getting emotional on me. I think the setup is outstanding personally and would recommend this to anyone.
