A full width front bumper on a Jeep JK Wrangler is something that Chrysler is required to provide in order to meet federal safety standards and, while I'm sure they do their job, they're a complete nuisance out on the trail. They get in the way of rocks, they effectively reduce your approach angles, they make it difficult for you to disconnect your sway bar links and being that they're just plastic, they start to look pretty bad after just a few minor hits on the trail. And, it’s for these reasons that chopping up the front bumper and making it into a stubby is one of the most popular, useful and effective modifications that you can make on your Jeep JK Wrangler. Of course, in addition to all the benefits you will get from this mod, the best part about doing this is that it can be done for next to nothing and this write-up will show you how.
What you will need
• 9/16" Socket & Wrench
• 3/8×1" Bolt
• 3/8" Nut
• Ratchet
• Hand Drill
• 9/16" Metal Drill Bit
• Sawzall w/Metal Cutting Blade
• Grinder
• Ruler
• Masking Tape
• Pencil
• Rubbing Alcohol
• Flat Black Touch-Up Paint
Instructions
1. Using some rubbing alcohol, clean the plastic surface of your factory front bumper. This will help remove any oils that would otherwise make it difficult for masking tape to adhere to it.
2. Using a small ruler and a pencil, measure out from the bump pad and mark a point on top of your front bumper as shown in this pic. For my purposes, I made a mark about 5/8" from the edge of the bump pad.
3. Once again, use a small ruler and pencil to measure out from the bump pad and mark a point on the front face of your front bumper as shown in this pic. For my purposes, I made a mark about 2" from the edge of the bump pad.
4. Create a cutting guide by applying masking tape to your front bumper following the marks that you made.
5. Using a sawzall and a metal cutting blade, carefully cut through both the plastic shell and metal sub-structure of your front bumper as shown.
6. Using a grinder with a coarse sanding disc, clean up the edges of your cut.
7. Using a 9/16" metal drilling bit, drill a hole through the backside of your bumper metal sub-structure and plastic shell as shown in this pic.
8. Secure the metal sub-structure and plastic shell together using a 3/8×1" bolt and nut. A 9/16" socket and wrench will be needed for this job.
9. Apply some touch-up paint to the cut metal and then Repeat process on the opposite side of your Jeep. That’s all there is to it. You now have a JK with a factory stubby front bumper and for free. Please let me know if you have any questions.
Installed Photos
