pvanweelden
Ditto on the metal clips that were on your original mesh insert - you should have taken those off and put them on the daystar.
Also keep in mind - you have to really PUSH DOWN on the daystar panel so that the lower hooks snap into the two bottom attachments in the dash, it took a considerable amount of pressure for mine to finally snap in, from there (with the metal pieces up above) it snapped right in and has stayed put.
were the clips from your factory dash panel metal clips Flat Top?
