Video's up.
Couple of questions, but please don't take this observations wrong...I've built a few rigs over 40+ years
How much room from the noise of the WP to the radiator, I'm hoping their will be more room for a larger elect fan.
Why did you use that style of trans cooler...they just don't cool as well as a stacked plate cooler of the same size. Size for size a stacked plate cooler will get you 30-40* cooler.
Don't you think having the weight of the cooler and the plastic pin mounts will end up causing issues down the road especially for off road usage vs. a mount? Plastic gets brittle and also will end up eating the Aluminum tubes of the rad.
You elected not to use a engine oil cooler or didn't the 6.2 have that provision?
Funny you mentioned that! I saw that cooler and the mounting tabs and I assumed it was a placeholder or temporary set-up just to facilitate the engine installation process. I agree that a larger stacked cooler will be far more efficient for that transmission. Obviously I don't have empirical evidence, but the currently installed cooler appears to be less efficient than the factory Mopar cooler installed with the 2012 and later 3.6 autos.
And do yourself a favor and find a better mounting method for whichever cooler you install. I know from experience that those plastic retainers will slowly file away at your radiator core and condenser coils, which in turn will end up creating additional costly problems. I'd hate to see four cheap plastic mounting pins destroy your expensive custom Griffin radiator.
Can not wait to see Moby back in action with that Hemi!! How long till Supersized Moby makes it's YouTube debut on the rocks ?
2013 JKUR 4" Enforcer lift w/ 35" fierce attitude MTs , RR modular front bump w/ warnvr8k
Hard to say for sure but, we're hoping to be wheeling it by August.
Yup, you guessed it.... the time has finally come to give Moby a little boost in power! We weren't planning on it but, with all the headaches we've been having with our transmission, we decided to stop throwing money at it, take the plunge and do a motor swap... but not a HEMI. After a lot of research, we decided to go with an GM LS 6.2L V8 (L94) and 6L80 automatic transmission using the MoTech LS kit with a heavy duty radiator. We hope to run this with a 3:1 Atlas 2-speed and brand new Dynatrac ProRock 80 rear axle to soak up all the additional power. This thread has been started to document the process of our Jeep JK Wrangler LS swap and we hope that you'll enjoy the build.
THE PLAN:
- LS 6.2L V8 (L94)
 - 6L80 6-Speed Automatic Transmission
 - MoTech LS Basic Kit
 - Heavy Duty Radiator
 - Advance Adapters 3:1 Atlas 2-speed Transfer Case
 - Dynatrac ProRock 80 Rear Axle
 - ATX Slab Bead Lock Wheels
 - NITTO 40x13.50 K-Spec Trail Grapplers
LS SWAP UPDATES:
THE PROCESS:
- DAY 1 - TEARDOWN
 - DAY 2 - OUT WITH THE OLD
 - DAY 3 - GETTING THE LS READY
 - DAY 4 - IN WITH THE NEW LS
 - DAY 5 - ATLAS TIME
 - DAY 6 - BODY TOUCHDOWN
 - DAY 7 - WIRING AND INITIAL FIRE-UP
THE PARTS:
- LS 6.2L V8 (L94)
 - MoTech LS Kit
 - MoTech Cruise Control and Tap Shift
 - Parts Sent to MoTech
 - Parts Back from MoTech
 - Exhaust Manifolds
 - Wiring Harness from MoTech
 - GM Cats
 - GM Sensors
THE COST:
(so far - not including tax or shipping)
VIDEOS:
Let the SUPERSIZING Begin : Short Timelapse Video of Moby's LS Swap
Just for fun, here are the listed horsepower and torque numbers for a stock Jeep JK Wrangler 3.8L V6 and 3.6L V6 Pentastar motor compared to a 6.2L V8 motor:
Jeep JK Wrangler - 3.8L V6
205 hp @ 5,200 rpm
240 ft-lbs. @ 4,000 rpm
Jeep JK Wrangler - 3.6L V6
285 hp @ 6400 rpm
260 ft-lbs. @ 4800 rpm
GM Vortec L94 - 6.2L V8
403 hp @ 5700 rpm
417 lb-ft @ 4300 rpm
Time to Start Shopping
First on our list was to find a used LS engine/transmission from a 2007+ Silverado, Yukon or Escalade. From what we were told, it would also have to be from a truck/SUV that was a 4WD. After doing some searching, we finally found what we were looking for, a 2011 Yukon Denali 4WD 6.2L motor and transmission and if you can believe it, it only had 12,000 miles on it! Here are a few pics of it at the junkyard we found it at:
After checking it out, we agreed it was too good to pass up and so, we went ahead and bought it.As you can see, it is now sitting at Off Road Evolution with Moby just waiting for more parts to show up!
We've got more parts on order and will be posting them up as they come in. Be sure to check back for updates![]()
Damn straight!! :cheesy:
I talked to MoTech about this and they recommended mounting it on the side of the steering column but, I may have to consider what Turnkey is going to do for Moochie.
Yes, this was an option and one we had considered.
Mmmm, love the smell of fresh axles in the morning...
