The bump can is notched into the frame but out plate is just on the outside to add strength.Looks good. Are the rear king bumps Frenched into the frame or welded to the outside of it? Would love to get them one day.
It’s actually orangeLooks awesome Jeremy!
I spy a red hovering gladiator as well
Ok. Thats what I thought. After my van is finished the Jeep is getting some love. I habe several projects that need to get done. Maybe I'll habe you ship me some rear bumps to pit on the list...hahaThe bump can is notched into the frame but out plate is just on the outside to add strength.
Sounds good!Ok. Thats what I thought. After my van is finished the Jeep is getting some love. I habe several projects that need to get done. Maybe I'll habe you ship me some rear bumps to pit on the list...haha
Very nice workThe bumps mounted up.
After sanding down the bolts a bit. Pretty happy with how they turned out. Obviously nothing crazy but had fun coming up with a solution for a clean and functional look.
And of course the axles all painted and ready to hang in the Jeep!
Stoked to see how you like their stuff. I just ordered their 3 link front/4 link rear for my JK.It’s actually orangewill post up on that one soon as it’s getting the RPM 3-link long arm kit. First time doing one from them. The Red one is going up hopefully this next week
It’s all the same 2” aluminum arms (like their steering) with Johnny joints on both ends. It is nice they have reversed threaded joints on one end on all the arms for mounted adjustability. The coils that came with the JT kit were Rock Krawler so assuming they partnered with them. So far the front replacement cross member and brackets look nice and stout so farStoked to see how you like their stuff. I just ordered their 3 link front/4 link rear for my JK.
That’s great to hear. Definitely will be hitting you guys up once I’m in a position for the jeep to be down for a while. The front 3 link I could handle, the rear… that’s a bit above my pay grade.It’s all
It’s all the same 2” aluminum arms (like their steering) with Johnny joints on both ends. It is nice they have reversed threaded joints on one end on all the arms for mounted adjustability. The coils that came with the JT kit were Rock Krawler so assuming they partnered with them. So far the front replacement cross member and brackets look nice and stout so far![]()
You doing the standard long arm or double triangulated rear setup?That’s great to hear. Definitely will be hitting you guys up once I’m in a position for the jeep to be down for a while. The front 3 link I could handle, the rear… that’s a bit above my pay grade.
I’m doing the DT rear, been running the MB rear tank for a bit now in prep for that system.You doing the standard long arm or double triangulated rear setup?
Ok nice. Sounds like a planI’m doing the DT rear, been running the MB rear tank for a bit now in prep for that system.
Looking good, Will drive shafts be changed on this build?Here is an update on the JT RPM Steering 4.5” 3-Link hybrid kit we are doing.
The front kit replaces the lower and upper control arm mounts for the long arms so all need to be removed. They also incorporate the lower brackets into the new transmission crossmember. This also means the factory crossmember and all frame mounting brackets get removed. An exhaust loop delete kit is also needed.
This kit is technically bolt-in only if you wanted but we will be welding in the upper third link bracket. Of course we want to keep the transmission bracket bolt-in only for obvious reasons.
Here are the front long arms.
Being this is their hybrid kit, the rear still uses the factory brackets and short arms. Their kits also use Rock Krawler coils from what we noticed. The FOX shocks were provided by the customer and not included.
I do like the fact they use johnny joints on all ends and that the arm is adjustable while mounted as one end is reverse threaded. You can also see just how crappy the JT rear axles get at full droop with factory brackets.
