TheGrendel
My gladiator doesn’t have the OEM panel. What do y’all recommend? I would like to use the OEM location given how useless that little storage pocket is.
			I have switchpros on my JK. I just like the thought of mounting the panel in the OEM location.I recommend Switch Pros. The switch panel is super universal for mounting locations and just a solid unit.
This. Looks the cleanest.If four switches is all you need go with the OEM one. Super easy install as well. If more Switch Pros is the way to go.
100%Go OEM. That’s what I did.
^^^^ Me tooGo OEM. That’s what I did.
Exactly…How does the oem aux work? Don't you have to install some sort of relay box with it and enable it in the ecu?
I have had the RC in my JKU for almost 4 years and the only issue has been a couple of switch lights burn out. Called RC and they sent me a couple new ones.I did the Rough Country MLC6 that goes in the factory AUX switch location. Works well and I’m pretty happy with it. Pretty simple install and decent instructions to follow. One thing I don’t like is I wish the light switches were lit up all the time - they only light up when the switch is turned on.
