Jsouder53
If you pull the track bar bolt and turn it around it will help.
You’re a genius! I’ll take care of that soon
All of the bumpstops are in! Got to the last one (rear passenger side) and it looks like the bumpstop will contact the rear upper track bar bracket and actually it looks like it has made contact in the past... View attachment 307498
Is my axle too far back?
Are your rear arms all stock? It should line up. The rear springs are easy to pop out, I would remove them with the frame up on jack stands and jack up the axle and see where it lands
Looks like it might be mis-aligned. You have to remember that the axel moves on an arc. Your extensions move the contact zone straight up. The bump may contact the edge of the extension instead of landing on the top since it’s so tall. Like Jkbrick mentioned, I would either remove the spring and use a jack to test or find a ditch that you can carefully flex in so you can verify the bump landing.
Those stops look awfully small in diameter. Most rear stops are larger diameter or rectangular in shape. Did they come with your kit?
I did mainly because I know how bad I am when it comes to greasing stuff.Just a thought... if the money is available when I go to ORE to re gear, I might upgrade my rear drive shaft. I’ve already changed out the front drive shaft to a rugged ridge when I lifted the Jeep. I am thinking of a 1350 Adams Driveshaft. My question is, should I go with the extreme duty solid u joint?
I did mainly because I know how bad I am when it comes to greasing stuff. [emoji849]
Looks like a fun day! Good to see you out exploring your new home.
Looks amazing there!
It looks so beautiful there and unpopulated, so jealous. I’m with you the more I drive the Jeep the more comfortable I am in its abilities
Awesome pictures, there’s nothing better than putting all that hard work on the rig out on the trail and watching it preform better that you thought it ever could have!
It is absolutely amazing! I want to take my canoe up to that lake![]()
It is absolutely beautiful [emoji106] we only saw a couple others that were camping on the trail. My main area of discomfort was being off camber while on rocks, especially when leaning towards a drop and slope.
Thank you! And it’s really the first time I’ve put it to a test... I’ve been to off road parks that really weren’t any kind of challenge compared to this!
Trails are so much better than parks. On top of better terrain, the best part is you are actually going somewhere. Not just around a park from one obstacle to another.
You, sir, are a crazy person.It’s official! We will be heading to Off Road Evolution in June of 2019!
List of work to be done:
- regearing to 4.88
- evo long arms
- evo plush ride coils
