Oreo_penguin536
Used my winch for the first time and I had a few question. Keep in mind we were on a icy hill and slightly off camber
1: when you’re winching, do you just let the line lay on the spool however it does or do you have a way to guide it back on semi straight without endangering yourself too much
Not sure if I asked this before but
2: Do I need pretension the line everytime after I’m done winching or is that a 1 time thing?
WJCO I know you said if you spool it spastically you don’t need to pretension it but I was curious
3: does the angle matter for mechanical advantage? I had to do a redirect off a tree and was curious as to which angle is most efficient or if it matters that much *see picture below for reference, actual scenario was upper right corner*
